file not found .dwg
file not found .dwg
Message 1 of 13
file not found .dwg
I am using Autocadd Electrical 2015. I have a problem of "file not found **.dwg" error whenever I try to insert components from the Icon Menu. Please help.
Replies (12)
Message 2 of 13
rhesusminus
Something is wrong with your symbol library paths.
In the project manager, right click on your project and select Properties...
Check that the paths marked in orange in the picture below actually points to the folders where the symbol libraries are.
If you're unsure about the location of the symbol libraries you can try to
  1. Select Schematic Libraries
  2. Click the Default-button
This should reset the folders to the default location.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 3 of 13
Thanks for the help.
Message 4 of 13
Great stuff! Thank you!
Message 5 of 13
I tried clicking default, it changed all the paths, but I get the same error.
The library paths all reference JIC
The schematic Icon menu is ACE_IEC_Menu.DAT
I want IEC symbols
Message 6 of 13
rhesusminus
You should edit your WD.ENV file, the row starting with WD_LIB and WD_PNL.
Something like this.
WD_LIB,%SL_DIR%/iec2;%SL_DIR%/iec2/1-;%SL_DIR%/pneu_iso125;%SL_DIR%/pid;%SL_DIR%/hyd_iso125, schem, 1-line, and pneumatic/pid/hydraulic default paths
WD_PNL,%SL_DIR%/panel, panel layout symbol library base folder
Restart AutoCAD Electrical, and now the "default"-button will use those paths instead.
Trond Hasse Lie
Ctrl Alt El
Message 7 of 13
That changed what the default button did, but I still don't have symbols. I still get the DWG file not found.
As a side note, I tried following the directory paths that show up for the schematic libraries on the project properties. I get close, but not the same
The project properties have paths like: C:/users/public/documents/Autodesk/acade 2014/libs/iec2
In windows explorer, the closest I get is:
C:\Users\Public\Documents\Autodesk\Acade 2014\Libs\iec-60617
(this is not what the browse tree looks like, but it is what gets copied as the text version of the directory path. I'm assuming windows is doing some sort of directory tree conversion for me.)
I assume there is some way the text you sent me is getting converted into what shows up in the project properties.
Message 8 of 13
rhesusminus
Ok. Use / or \
It doesn't matter.
Replace IEC2 with IEC-60617 in the WD_LIB line in WD.ENV
Trond Hasse Lie
Ctrl Alt El
Message 9 of 13
I am getting the same error with my AutoCad Electrical 2018. I am using IEC symbols but on certain symbols I get the file not found.
I tried to add the IEC Symbol library as per the suggestion but I don't have the IEC option to add. What should I try?
Please see attached
Message 10 of 13
Icemanau
In your case, it means that the library was not installed when the program was installed.
Exit ACADE
Go to Programs and Features (Win 7) or Apps (Win 10)
Click on Autodesk Electrical
When the installer comes up, select 'Add or Remove Features'
Click Next to get to the page with the symbol libraries
Select the required library(ies) you want to add
Click Next and I would recommend making sure the Express Tools feature has been installed before clicking Update
Once the update has finished, check the location of your libraries to make sure the new folder and its contents have been installed
Restart ACADE and try adding the IEC library again
Regards Brad
Brad Coleman, Electrical Draftsman
Message 11 of 13
@rhesusminus
Trond, this helped me in 2020!!
Thanks!!
Message 12 of 13
t_d_titi87
Community Visitor
Community Visitor
😍😍AWSOME
Message 13 of 13
juanVHTFR
Observer
Observer
Wow, that was helpful.
