Hello all, I did use Rating 5 attribute to indicate a Kit# for my parts, the issue I am having is that when I run the BOM report the Rating 5 column always
Yes I do. when I built my panel layout I used Schematic List Icon, so all the data from schematic are present in footprints, but i wasn't able to transfer it to the BOM.
If you can use the COmponent report, you'll be able to get the rating attributes:
Thank you for responding. Yes, I added it to User Attributes, and this is where I made a mistake. I typed Rating 5 and it did not like that. Once I changed it to RATING5, it worked just fine.
Again, thank you.
