hi everyone,
I'll try to upgrade ACADE by Express Tools.
during the installation an error message appears:".NET 4.5 not installed ..." but I've checked and in my PC there is installed already .NET 4.5.
Could anyone help me?
thanks a lot!!
Solved by yuvaraj_jaganathan. Go to Solution.
A real quick question first off which will allow us to help you better...
What release of ACADE are you using?
Including this information in your questions will lead to quicker answers as each release of ACADE has some major differences from the prior releases.
To track down a problem or to answer a How-To question requires us to know which release we should be looking at and as much other information as possible (workflow which causes the problem as an example).
Regards Brad
Brad Coleman, Electrical Draftsman
The steps mentioned in the following link might resolve the issue.
hello,
I've ACADE 2015...
in anyway I'll try to follow the Yuvaray suggestion, I'll give you the feed back of the result.
Davide Tomelleri
hi,
sorry for delay...
I've just try follow the Yuvaray suggestion and ... Yhea! It runs!
thank you so much!
Davide Tomelleri
