I rebuilt the project
Then re-ran the item number resequence
Rebuilt the project once again
The bill of material REPORT had duplicate records (for terminals) for the same part number, only different quantities in each.
When added together, the quantity was correct however.
Some sub-quantity (assembly code) items had item numbers assigned to them (fuses - fused terminal blocks), though they are not inserted anywhere else in the drawing set individually.
This may be why the 2 were not combined when I did a resequence of the item numbers.
Used the export feature and exported everything
Removed all "Item" and all "P_Item" values
Re-imported.
Wham, NO catalog information in the panel layout terminal blocks that had previously been inserted, all other blocks were correct.
On a side note and a MAJOR BUG out of the box of 2018, I NOTED MANY OF THE STOCK AUTODESK TERMINAL BLOCKS FOR PANEL LAYOUTS HAVE DUPLICATE ATTRIBUTES including the CAT attribute,
THOUGH THIS IS NOT THE CAUSE OF THIS ISSUE. Discovered this the other day when I would change the catalog number in the schematics, but the bill would not come out right.
Apparently when a catalog number changes in the schematic, it updates the first listed CAT attribute in the block.
When you run a report, it pulls from the last CAT attribute in the block.
Whats that? Comos Calling????
