AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Electromechanical - I don't use it - can it be disabled?
2 REPLIES 2
vladop
106 Views, 2 Replies
Can the Electromechanical link be disabled?
The answer is probably "No".
Would it speed up ACADE'?
2 REPLIES 2
OP21
in reply to: vladop
If you are referring to syncing issues to Inventor then you can set this variable AEEMXDATAUPDATEMODE =1.
Check this post if it better describes what you are experiencing..
Solved: Sync Failed - 2016 - Autodesk Community
Hope this helps!
Omar
P.S. If this did help you, remember to "Accept as Solution", so the answer can help others. "LIKES" are always welcomed and much appreciated! Thank-you.
vladop
in reply to: OP21
I haven't had any problems. I just want to disable unnecessary things, and I think this is exactly what I was looking for.
Thanks.
