Editable revision triangle
snorcisa7FS8E
snorcisa7FS8E
I'd like to create a editable revision triangle to be selected from the icon menu or something similar, but that can be shared with other users. I've tried making it a block and editing the icon menu to be able to select it from there
but when it comes in it's not editable unless you explode it. Is there an easy way I'm not thinking of?
OP21
Just add an attribute to the revision block. During the block creation phase you can select the check box parameter of the attribute to "verify", this way each time you insert the block it will prompt you for the value or you can predefine a default value and change it during the insertion.
Hope this helps!
Omar
P.S. If this did help you, remember to "Accept as Solution", so the answer can help others. "LIKES" are always welcomed and much appreciated! Thank-you.
snorcisa7FS8E
The weird thing is that some sheets of the schematic are at different revision levels than others. Would this attribute be reading from the title block attribute on the ,wdt file or from what's actually in the title block of the sheet it's inserted into? Because they will be different.
OP21
This would a manual entry each time the revision triangle is added to the drawing.
Hope this helps!
Omar
snorcisa7FS8E
Aaaahhhh!
That sounds just like what I'm looking for.
TY!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
