Edit/Delete Jumpers error
acclarkJR2TJ
acclarkJR2TJ
I am beyond fed up with the lack of focus on fixing the AutoCAD Electrical Terminal Strip Editor issues. Autodesk are you paying attention to your customers? I didn't think so.
We have had enough of you ignoring issues that we keep complaining about and all you want to do is put out a new version every year without fixing the big issues. Before you decide to put out some new little addition, how about you fix the old issues that have been around for 10+ years.
I am trying to delete an old jumper set but I can't, because ACADE gives me a stupid error that means absolutely nothing:
I have found ZERO quick fixes, I have to delete EVERY SINGLE TERMINAL and then put them back in. That equals several HOURS, hours that Autodesk should pay for since they don't want to fix the issue.
rhesusminus
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
alds02
"Mulitiple". Sad that we pay for spelling errors too.
jaya_priya_ramasamy
Hi @acclarkJR2TJ ,
Sorry that you are facing this issue with jumpers.
@rhesusminus had given the below solution sometime back
Solved: Issues with Terminal Jumpers remaining even after deletion - Autodesk Community - AutoCAD El...
Have you tried it?
Is it possible to get the data set to try out?
Jaya Priya Ramasamy
Senior QA Analyst
www.autodesk.com
acclarkJR2TJ
Hey Jaya,
No, I didn't have time to wait for an answer for that particular question, but that wasn't the first time that issue has happened. I basically had to delete every single terminal in that series, it was 5 hours of work that shouldn't have been required.
As for providing the project for you to use as a test, I wouldn't be able to do that at the present time.
jaya_priya_ramasamy
Hi @acclarkJR2TJ ,
Thank you for the reply. I request you to send me the project when you have time after deleting any confidential info. This would be really helpful for us to check the issue.
You can send to my email address: jaya.priya.ramasamy@autodesk.com
Jaya Priya Ramasamy
Senior QA Analyst
www.autodesk.com
