Message 1 of 10
Edit component will not substitute in a new part.
11:39 AM
I'm using AE2017, I'm having an issue.
When I substitute in a new part from the catalog selection and click OK, the original part is re-populated. The Pin list pop-up window doesn't occur.
- I've cycled my computer. This did not work.
- I turned off AutoCAD Electric. From an earlier post (CAN'T CHANGE CATALOG ASSIGNMENT WIHT INSERT/EDIT COMPONENT (AEEDITCOMPONENT)) in 2017 of the same issue, I did the following. However, the earlier post didn't have a resolution. The video in the earlier post is exactly the same issue.
- I deleted C:\Users\<User name>\AppData\Roaming\Autodesk\AutoCAD Electrical 2018\R22.0\enu\Support\User\name.mdb.
- Restarted AE2017.
- This did not work.
- This occurs on a few components but not all components of the same page.
- I had a co-worker make the required change and it worked for him. After he made the change, my system still had the same issue.
