Hi Folks,
I noticed that when I have the same CAT/MFG with different counts, the Panel BOM report generates duplicate rows of the same part - see attached. For example,
Two of the same item with COUNT 1 and 3 respectively... then two rows = QTy 1 and QTY 3 separately (not good)
but two of the same item with counts 2 and 2 respectively... then one row = QTY 4 (good)
Is there a way to consolidate the same part into one row regardless of the counts?
Note that I need to use Normal Tallied Format because I have other items that use sub/multi-catalog and do not want them to be broken out, such as item 7 in the attached jpg).
Ken
When running your BoM report... does selecting "USER POST > QtyxSubQty consolidate the item number?
