Drawings gone crazy problem with text and attributes and wire numbers
I´m having a problem with text and attributes. When I´m working on a drawing sometimes all text, attributes an references, wire numbers seems to changes size and go out of place. I hade this problem in ACE 2015, then I needed to restart the program and the drawing fixed it self. But in 2017 it doesnt fixe it self and stays incorrect. I can go and retag/update references and the will go back to normal, but in some time it will happen again. I need to get this fixed, this is costing me serious problems.
See attached file
Accepted solutions (4)
Her is another drawing witch shows the problem better.
TRLitsey
Hi there,
A little help with the scope of what is going on: Is this suddenly occurring with a drawing you have open?  Does this happen when you are opening a drawing you were previously working on?  Has anyone else been working on the drawing?  Did you create this as a new drawing or did you copy the drawing and then start working on it?  Have you checked the font setting for the drawing?
The origin of the drawing might be a big clue.
As a stop gap, have you applied the Project Settings to the drawing? Is this a project you created or did you copy someone’s project and it is not working as you expect?  Did you dive into a project someone else created?
Apply project defaults ...
Check font settings ... Menu Bar , Format  >  Text  .  if you do not see the Menu Bar type menubar on the command line and set the value to = 1
Please mark as a solution if this works for you, kudos are always welcome  -  thank you
Good luck
rhesusminus
Hi!
If this happens on every drawing on AutoCAD 2017, is it a font problem?
You you type "style" on the command line, and go through the list of style, do any of them have a warning icon in front of the font name?
I've experienced a problem with attributes not being justified correctly previously, and did a VBA-macro to fix it:
http://forums.autodesk.com/t5/autocad-electrical-forum/block-attribute-text-not-center-justifying-co...
Is this something that would help you?
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Icemanau
I normally see this when someone with either an older version of ACAD/ACADE or without the correct font installed opens and then saves a dwg.
If ACAD/ACADE can't find the specified font, it substitutes a generic font which may have different latter spacing/sizes.
This then causes problems with the display of text and attributes that use the substituted font.
There isn't much that can be done about this other than making sure that ALL ACAD installs have the correct fonts.
Regards Brad
Brad Coleman, Electrical Draftsman
Well that’s what I´m ben thinking, Font problem.
I found a corrupted drawing in the project I´m working on known, and when I deleted it from the project everything went back too normal. Looks like that drawing were forcing the project font to change.
Thanks guys for your help.
TRLitsey
Hi there,
You may already know this but I think it is worth mentioning. When a new drawing is created within a project the template settings and project settings are applied to the new drawing.  If a drawing is copied it will retain whatever setting had been previously adjusted.  ACE is built to work this way but it can create some land mines if you are not checking the setting when you copy a drawing.  The idea is so that within a project one drawing could be a huge balloon and bill of material drawing with certain snap / grid / font etc.  settings and the schematic in the same project can have alternate setting.  Just an FYI.
Good luck
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
