Hello.
I was trying to add pneumatic components in a new drawing when I noticed about some blocks are disproportionate respect other same kind components. I mean, for example when I put an flow path 5/3 with the schematic scale set in 1 the block was too tiny for the scheme, on the other hand, a 4 way valve seemed to be in a proper scale. Also, check valves and mufflers seem bigger than they should, I'll attach a picture about this problem.
I tried to change the scale factor but the text change too, making the drawing disordered.
How can I fix the scale between components without changing the text size?
Thanks for your attention.
PS: English is my second language, sorry for the mistake if I made one.
