AutoCAD Electrical Forum
Display X-Y Grid Coordinates - AutoCAD Electrical 2022
3 REPLIES 3
mrshayboo
401 Views, 3 Replies
mrshayboo
I was wondering if there was a way to display the X-Y Coordinates of my cursor or a certain component, as it is difficult to locate a component or an area on the drawing otherwise.
In terms of the picture, could you display the coordinates 2-C somewhere as it is a self-made boundary so not sure if AutoCAD could pick this up.
Would save me scrolling to each edge to see where I am on a drawing.
3 REPLIES 3
rhesusminus
in reply to: mrshayboo
rhesusminus
You can't do this with out-of-the-box AcadE functionality. Everything can be done by some programming of course.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Trond Hasse Lie
Ctrl Alt El
mrshayboo
in reply to: rhesusminus
mrshayboo
HI, Thanks for the reply, could you point me in the right direction on where I can look to lesrn the programming required for such functions.
rhesusminus
rhesusminus
Learn C#: https://www.linkedin.com/learning/search?keywords=c%23
Learn the AutoCAD API: http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%20.NET%20Developer%27s%20Guide/index.html
Psuedocode:
- On open/activate new drawing get the WD_M block
- Read the values of the attributes XY_DELIM, SHEET, HORIZ_FIRST, CHAR_V, CHAR_H, DISTV, DISTH, DATUMX, DATUMH
- Start loop
- Get the current cursor position
- Calculate the position of the cursor within the sheet using the fetches coordinates
- Put the calculated value somewhere (Tooltip on cursor?)
- Goto start loop
Trond Hasse Lie
Ctrl Alt El
Psuedocode:
- Start loop
- Goto start loop
Trond Hasse Lie
Ctrl Alt El
