Under the Templates entry there should be at least 4 entries depending on what version of ACADE you are using.
This shot is from 2008 but the entries are still existing in 2018.
As you can see, there is an entry to set the Templates FOLDER (Blue Explanation) and an entry to select the default QNEW Template (Red Explanation)
QNEW stands for Quick NEW dwg and creates a dwg without adding it to the project or setting up any of the dwg properties/settings. It just uses the named template to quickly start a new dwg with the settings saved in the template. Useful when you need to have the ribbon or Project Commands active without opening a project dwg or to do a quick sketch without going through the hassle of adding it to a project.
The New Dwg button in the Project Menu actually adds the dwg to the active project and brings up the New Dwg Settings dialog which has the ability to choose a different Template if required as shown by @TRLitsey.
This template choice is saved as the new default template for this method of dwg creation from session to session. This allows the user to select a new template according to client requirements which the QNEW system doesn't.
Regards Brad
Brad Coleman, Electrical Draftsman
