Someone from Autodesk may be able to shed a better light on this, but until
they do, I will give my best answer. The connectors are built using the
same method as the Parametric PLC builder. It is actually a variation of
the Parametric PLC code. The blocks that make up the I/O points can be
edited but the actual outline of the PLC is dynamically built by AcadE to
match the scale of the blocks. I think the connector builder works the same
way.
wrote in message news:5874607@discussion.autodesk.com...
How can we create our own Custom Connector Symbol and still use the
"Connector Utilities"? I like the options the Utility has to offer; but we
do not like the symbol that is default connector.
I can imagine there must be a way to change this since there are ways to
change the Cable symbols and Source/Destination symbols; but I cannot even
find a command line used to call the connector.
I realize the utility builds a component on the fly, so even looking for the
block to modify is useless.
Can anyone help? We cannot be the only company that wants to use a different
symbol, then the one offered by default.
Thanks.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
