Cross Reference Format Components vs Source/Destination
NReichmanR6N4Y
NReichmanR6N4Y
How would I set up my cross-reference so that my components use the #S—#N format and my source and destination only use the #N format? The picture below is how I want it set up.
Right now, I need to take an extra step by changing the drawing properties, doing a Component Cross-reference update, changing the drawing properties again, and then doing an Update Signal Reference.
I want to avoid doing this step.
jed43243
Observer
Observer
Did you ever figure this out? I am struggling with the same issue.
NReichmanR6N4Y
No, I wasn't able to figure it out.
arshdeepsingh404
Hi @NReichmanR6N4Y  @jed43243
If you don't want to display the sheet number on source destination arrows (Only #N), You can try setting the SHEET attribute to invisible and move the XREF attribute to display in center.
Arshdeep Singh
Electrical Designer & Programmer
C.Tech | CAPM® | CMSE® | Autodesk Expert Elite
LinkedIn
