Configurable default location for .TSL files
Cole64
Cole64
I use .tsl files for creating custom Tabular Terminal Strips which for example may differ if cable is coming into a enclosure or out or both. I wanted to point ACADE to a location of my server where I keep my custom .tsl files, where at present ACADE default browse location is set locally in the users file location and it gets frustrating navigating to the server all the time.
There is this post http://myacade.blogspot.com/2013/02/breaking-wdenv-file-down-line-by-line.html that explains all the configuration that can be done to the WD.env file but there is no reference to set where the default location is for .tsl files. Having a defaul location configuration for the .tsl files in the WD.env file would be very helpful.
rhesusminus
This seems to be hardcoded into AcadE, like a million other annoying things.
The only workaround I can suggest, is to add the server-based flder to "favorites", using the button in the top right corner of the "browse for TSL-file dialog".
With the neighboring button, you can quickly navigate to that favorited folder.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Cole64
Awesome, I haven't noticed those favourite buttons. That will definitely help. Thanks
