Component tag based on Reference Numbers
boologaraja_s
Message 1 of 15
boologaraja_s
Hi All,
I have to fix the component tag based on the Reference based.
Reference number - 0113, component tag for 3p fused disconnect - DS0113
Reference number - 0117, component tag for 3p fuse - FU0117
It's automatic possible?
Replies (14)
Message 2 of 15
alds02
Yes. You can set this up in Drawing Properties.
If you think it is already set up but not working, please post some screenshots to help us diagnose the issue.
Message 3 of 15
boologaraja_s
Hi, how can I set this in Drawing properties? let me know.
In component tag format, I assign the %F%N format, there is any other method is there.
Message 4 of 15
boologaraja_s
How can I set this in Drawing Properties? let me know.
In Component tag format, I assigned the %F%N format, there is any other method is there?
Message 5 of 15
arshdeepsingh404
Hi @boologaraja_s
Your component tagging %F%N seems to be set correctly.
What kind of referencing are you using (Drawing Properties > Format Referencing)?
Follow this video exactly and check if you are to reproduce the results.
(view in My Videos)
Arshdeep Singh
Electrical Designer & Programmer
C.Tech | CAPM® | CMSE® | Autodesk Expert Elite
LinkedIn
Autodesk App Store
Did you find this post helpful? Please feel free to Like this post.
Did your question get successfully answered? Please click the Accept Solution button to help other users who may have the same question.
Message 6 of 15
boologaraja_s
Hi Arshdeepsingh,
Thanks for your kind reply on this.
In this section, I am using line reference numbers based on sheet and numbers basis.
By using this, the component tag assigned not based on line reference numbers.
Any other solution is there?
Message 7 of 15
jaya_priya_ramasamy
Hi @boologaraja_s ,
You can follow the topic Fix Tags Project-Wide in the below help document.
AutoCAD Electrical 2025 Help | To Work With Settings Tags as Fixed | Autodesk
Jaya Priya Ramasamy
Senior QA Analyst
www.autodesk.com
Message 8 of 15
boologaraja_s
Hi @jaya_priya_ramasamy
By using the Fix tag Project-wide, the component tag not changed.
The Component tag for DS02, I required as DS0113.
For tag FU03, I required as FU0117.
For tag L03, I required as L0117 like that.
Any solution is there?
Message 9 of 15
jaya_priya_ramasamy
Hi @boologaraja_s ,
You can use reference-based tags and do normal tagging first. Then finally do Fixed tag project wide using project-wide utility.
Jaya Priya Ramasamy
Senior QA Analyst
www.autodesk.com
Message 10 of 15
boologaraja_s
Hi @jaya_priya_ramasamy,
Actually, I am not getting the component tags based on Line-reference.
Message 11 of 15
rhesusminus
I guess we need to see your dwg to find out what the problem is.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 12 of 15
boologaraja_s
Hi @rhesusminus,
In the drawing section, customer asked the page number based component tags.
I enclosed herewith the drawing FYR.
Message 13 of 15
rhesusminus
Delete your reference line numbers and reinsert them.
Set your compoent tagging mode to %F%S%N
Retag all components.
Result:
Trond Hasse Lie
Ctrl Alt El
Message 14 of 15
boologaraja_s
Hi @rhesusminus,
Thank you for kindly help on this.,😊 Now it's working fine.,
Message 15 of 15
boologaraja_s
Hi @rhesusminus,
Thank you for kindly on this ., 😊
