Component Insert - not going to correct layer
pmccutcheon
pmccutcheon
ACE 2019 on WIN 10
I am having an issue with Component Insert where the block doesn't go to the correct layer.
Suppose I am on a wire layer BLU 16 AWG.
When I insert a component (using the AE command) the inserted block winds up on BLUE 16 AWG.
Normally the DESC attributes should be RED, (the DESC layer color) but will turn out BLU.
Likewise INST and LOC are the wrong color.
This feature was previously working, and I am editing a drawing where blocks were previously inserted correctly. This is not a new install of ACE. The various components are not new, have all been used/tested before.
Some setting gone wrong in Autocad?
thanks
pmccutcheon
And answer is ... bad drawing properties, the drawing layers are not set properly.
What went wrong? copied a project, so this was a "working" drawing at some point, but the dwg properties got messed up during the project copy process. Likely the previous project had "good" dwg settings, but "bad" project settings.
arshdeepsingh404
Hello @pmccutcheon
Glad to hear you found the solution. You should consider marking your post as the accepted solution to close this thread.
I'm sure it will help someone else down the road.
Cheers
Arshdeep Singh, C.Tech, CMSE®
Electrical Designer & Programmer
Please mark as [Accept Solution] if this resolved your issue. It might help someone else with the same question. Likes are welcome!
Type a product name
