Component Duplicates
galashkina
Advisor Advisor
galashkina
I use the project "IECDEMO"
The "Schematic List" command is unclear.
At the first start, there is no information about the placement of components in the drawing.
I can select a component in the table and insert it again.
I press the "Reload" button.
Now all the components of the schema are marked as placed on the drawing, and I can not reinsert them.
If I close AutoCAD Electrical and open it again, then I run the " Schematic List " command, then all the components are available for re-inserting again.
Is this the ability to insert duplicate components?
Icemanau
You will notice that there are 3 buttons in the lower left side...
Sort List, Reload & Mark Existing.
When you initially load (or reload) a schematic list, make sure to click on the Mark Existing button.
This will tell ACADE to go through the panel layouts and check for any components in the list. If it does find a component, it will mark the list to show it has already been inserted.
Regards Brad
Brad Coleman, Electrical Draftsman
galashkina
Thank you, Brad!
I forgot about the  "
Mark Existing" button. Smiley Embarassed
