Component Cross References Gone Wild ACADE
When attempting to surf a parent component to go to the child, I get multiple references even though there is only one. Normally, the references look like so...
Type
Sheet, Reference
Instillation
Location
P
7, 40301
NO
12, 40800
1
But instead, I am getting references that look like these...
Type
Sheet, Reference
Instillation
Location
P
7, 40301
P
 , 40301
NO
12, 40800
NO
 , 40800
1
I was able to reverse this once or twice by doing a complete reboot of my system and Autocad Electrical would rewrite the registry values with its "First Run Initialization". But this only works once in a great, rare while. This is especially difficult to work with because when I do component retag/updates sheet wide, it will put in the rouge reference on the component.
At a loss with this one. Thanks for the help!
ACADE x64
Win7 Home Premium x64
Hi Tom
These "happenings" occure to me.  I have a few processers I go through to resolve problems.  I am using ace2012
You have done one    Reboot,   I always power off at the mains power  and reboot   This should reset any registers in a PC.   It did when I was a Mainframe service bloke.
Retag does not always work for me.
Changing the catalogue data via componant edit sometimes does not get reflected in the BOM.
There is a file that I delete that helps.
Close all drawings and ACE.
 C:\Users\<your name>\AppData\Roaming\Autodesk\AutoCAD Electrical 2012\R18.2\enu\Support\User
In this directory there will be a <Project Name>.mdb  The one that is mucking up.
Delete this file.   I use the shift key so that it will not go to the recycle bin.  It will be recreated when you restart ACE and open the offending project.
Sometimes I need to delete the offending symbol,  purge the drawing and re-enter the symbol.
This does not always fix the problem.
Sometimes if I go and do some drawing somewhere else and come back to the recalcetrant symbol and it works.
In my case there is a virus program that rund every few seconds and does a spot check that I feel mucks up ACE but I cant prove that due to company policy.
If someone has a more elegant solution i would like to read there solution.
In the AutoCAD forum there is a robust discussion re AutoDESk should be fixing bugs not adding new "buggy" features.   I could not agree more.
Keep an eye on memory use via windows task manager as this can be an indication that ACE will much up.
As an example: my system does a virus scan mid day Mondays.  At the end it leaves memory full and only very basic ACE commands work.
Once this process is finished I do the Reboot sequence I outlined above.
ACE also fills up memory.
This is just my experience and I hope it helps.
Cheers  john Q
I tried your solution with deleting the MDB file associated with the problem project and it seemed to have worked. Can now update drawing wide again.
...for now...
I did not have to delete the symbol out of the drawing for it to work either. But will definitly keep that in mind.
Also forgot to add I am on ACADE 2013.
Thanks for the advice John!
