common language runtime detected an invalid program
  I'm using AutoCAD electrical  2014, in Windows 7. I'm getting an error which titled "common language runtime detected an invalid program", when I tried to open my layer table ( means using command "LA"), or Isolating the layers ( Commond; LAYISO") etc, I can't create dynamic blocks. all that time it is showing the same error message. How can I solve this issue???? .. kindly help me bcoz I can't create a new layer in that.. this is hurting me a lot.. one error screen shot attached for your reference.. Plz..
  your response will be greatly appreciated..........
With Regards,
Sanoop.
iancross
HI Sanoop,
a runtime error could mean many things.
1st it could be an issue with your C++ runtime so try reinstalling these
2nd, have you applied the service packs???
3rd try logging into your pc as a different user, this will indicate if there is an issue with your profile, deleting your AutoCAD Electrical profile user profile C:\Users\USERNAME\AppData\Roaming\Autodesk\AutoCAD Electrical 2014
4th  do a full clean uninstall of ACADE deleting all known references and registry keys.
Ian
Ian Cross
www.xcrosstech.com
Vault, Inventor, and MFG Specialist
Across Technology, Across Industry
