Circuit Breakers tags
Arlene_Brown
Arlene_Brown
The IEC menu automatically labels circuit breakers as Q tags. Is this in line with the latest IEC regulations? Does anyone have a list of the latest tags for components used in a schematic diagram.
Thanks in advance.
rhesusminus
Try using the IEC-60617 library instead. It should be updated.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Arlene_Brown
Thanks for your reply.
I use IEC-60617.
Regards
jalger
Make a notepad file in your project folder called "WD_FAM.dat"
That will override the Family code tag for each component.
the format is:   <old Family code>,<the override family code>
Example:
CB, Circuit Breaker
LT, Light
what you see before will be:
 LT123, and CB101
after you add the WD_FAM.DAT file it will look like:
Light123 and Circuit Breaker101
In other words, it doesn't matter what library you you use you can kick the symbol tag over to something else.
I hope this helps,
James
James Alger
(I'm on several hundred posts as "algerj")
Work:
Dell Precision 5530 (Xeon E 2176M)
1tb SSD, 64GB RAM
Nvidia Quadro P2000, Win10
