Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor
Specializing in AutoCAD Electrical Implementation Support
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Click Find/Edit/Replace Component Text, as illustrated in my earlier post. You will see an option for Find/Edit/Replace Terminal Text but, believe it or not, that one doesn't change terminal tags (the TAGSTRIP attribute), it changes terminal number, like changing 1 to 2 or L1 to L2, etc. After you click on Find/Edit/Replace Component Text, select Project, OK, Do All, and OK. When you get to the screen shown in the attached image, check the box next to TAG and click List to find the terminal strip you wish to rename. If you prefer, you can just type in the Strip Name. Check the Replace box and type in the new terminal strip tag designation. Change the option radio button to All instead of Part, so the utility searches for an exact match, not a partial match. Click Start Search and at the next screen click Replace All.
Doug McAlexander
Doug im surprised you did not go with the dedicated block reasignment tool
1) Goto Panel> Editor
select terminal strip you wish to edit the presss edit
2) youcan now select a ny or all the terminals in the block and then press resign terminals
3) you can now browse to a different existing block details or enter new block details
click ok >oK>Done
and the project updates
I understood him to be asking how to change a Strip ID project wide, not renumber a strip. Maybe I misunderstood his inquiry.
TSE can renumber the individual terminals in a strip. But I don't usually use TSE for renumbering a strip, because it doesn't consider their appearance in the schematic as the sort order. I like to renumber according to their appearance in the schematic drawings. I use a couple of old commands that aren't in the ribbon. I made icons and added them to my ribbon. They are AERENUMPICK and AERENUMPROJ. The pick version prompts for a beginning number and every time you click a terminal it gets the next number. The project version prompts for a starting number and then renumbers all terminals in the strip in the order that they appear in the schematic drawings. I give the icons away to my students and it provides an opportunity to teach the CUI editor in my advanced class.
Depending upon the situation I might also use the spreadsheet export/import/update method to renumber a strip. But AERENUMPROJ is my preferred method because it uses the sort order to process each drawing of the project.
Doug McAlexander
Hi Doug.
Just wanted to point out that he meant terminal REASSIGN, not renumber.
I would also go with the TSE for reassigning ("renaming") terminals.
Right, I understood that. I guess I confused the issue when I posted about renumbering the strip. I was just trying to point out that sometimes even TSE is not the best choice for renumbering, because it renumbers from the panel layout side, which can sometimes cause the schematic terminals to not be numbered in order of their appearance in the schematic. I've had numerous customer complaints about that because they want their sequentially numbered terminal strips numbered in the order that they appear in the schematic. So I show each of these customers how to add the AETERMRENUMPROJ command to their ribbon.
The original post that started this thread referred to retagging the strip ID of 150 terminals in a strip all at once, changing from TB-2000 to TB-1. I prefer Find/Edit/Replace for that, though I am a huge fan of TSE.
My problem with using Terminal Reassign to retag an entire strip is that it requires me to rebuild or re-insert the graphical strip, and then it updates the related schematic symbols. That may be good if I'm working on panel layout, but if I'm on a schematic drawing, I'm going to be prompted to rebuild or insert new. TSE is actually more of a panel layout utility, so it is a great choice if I'm laying out the panel. But there is still a slight inconvenience using TSE to reassign the strip ID, even on a panel layout. I keep the TAGSTRIP attribute hidden by default on my terminal footprints and only make the TAGSTRIP attribute visible on one of the blocks, once the strip is inserted, so it is clear which strip it is. I don't use dumb text to call out a strip, because attributes are always searchable and replaceable using spreadsheet export, when the need arises. Dumb text isn't. Rebuild or Reinsert replaces the terminal footprints and then I have to unhide the TAGSTRIP attribute again, after every edit. Using the Find/Edit/Replace utility takes care of retagging the entire strip, schematic and panel layout symbols, without requiring me to rebuild or reinsert the graphical strip.
I'm sorry if I confused anyone.
Doug McAlexander
Doug,
I like to use TSE to do it because it gives me a little finer control on the process than a global change. For instance, I may want all but a couple of the terminals to be changed or I may also want to add some terminals or accessories at the same time.
I am also more confident of my links being maintained or re-established.
Your way works, it is sometimes just a matter of preference.
