Announcements
Changing Symbol Defaults
I frequently am changing symbols to show the CAT attribute & then having to resize the font. It would be nice if I could, en masse, have a way of defaulting all symbols to have that attribute shown & sized.  Any suggestions?  Thanks.
Replies (8)
jseefdrumr
You can use the Modify Symbol Library tool to change attribute text sizes in an entire library at once. There isn't a check box for the CAT attribute specifically but there is one for default text height; that might do the trick.
As for making it visible, normal behavior in ACADE is to leave un-populated attributes empty. If you want it to be displayed all the time, it needs to be populated with a value.
If you already are giving it a value, but the attribute remains invisible, then there is something else going on. You'd have to post back with more details in that case.
Jim Seefeldt
Electrical Engineering Technician
ramesh.kambang
The attribute CAT is invisible as a default unless it is made visible manually. There are two ways of making CAT visible:
1. Right-click>Attribute> List/Edit
2. Using unhide attribute
 3. If you want to make the CAT attribute permanently visible, open the symbol block and in the CAT properties, change Invisible to No.  Here you can also change height and size. You may need to swap/update the block on the current drawing if that block is already placed.
Ramesh Kambang
Aerospace System/Design Engineer and eVTOL/EWIS Expert
EASA 21J, UK 21J, MAA DAOS, Certification Specification CS23-29, CS-ANCS, CS-STAN and EVTOL
Please select "Accept Solution" if this post answers your question.
Thanks; I was hoping there was an easy way of batching that process out to multiple symbols so that I didn't have to open each one up separately.
Thanks. I was hoping the Modify Symbol Library tool would allow me to force the CAT attribute for all symbols. It's looking like I'll have to make it visible on each symbol individually.
ramesh.kambang
As Jim mentioned, you can change the text size for the symbols from the entire library. Unfortunately, visibility has to be done one by one. Probably someone comes with a new idea.
Ramesh Kambang
Appreciate the replies; thanks again.
rhesusminus
You can "just" write some lisp-code to make the CAT-attribute visible, and put it here:
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Icemanau
Another option is to change the blocks base dwg before using the swap update tool for the entire project.
You will have to make the changes to each blocks base dwg, and run the swap update on each individual blocks base dwg but it will easily do the entire project.
Just make sure to NOT select the option for attribute location.
Regards Brad
Brad Coleman, Electrical Draftsman
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
