Change the Signal Arrow Style
Hi everyone. got my project completed and would like to go back in to change the style of my "Signal Source and Destination Arrow Style" Currently I have chosen style 3 in my design, but would like to change it to style 4. Any help on how to replace the Signal Source/Destination Arrow Style would be appreciated. Can't afford to go back and delete existing to put new ones... easily close to 100 signal source/destinatons thanks AS
Icemanau
Use the Swap/Update tool to do swap the source/destination arrows project wide.
Open a dwg with both Source and Destination arrows in it.
Select one of the arrows and then bring up the properties for it so you can brad the name.
It will be HA3S# orHA3D# with the '#' being a number corresponding to the arrow direction. The S and D refer to the block being a source or destination. The HA is just the naming convention used by ACADE while the 3 denotes which style they are.
Start the Swap/Update tool and in the 'Option A: Swap Block' section, select 'Project Wide' with 'Browse to new block from file selection dialog'
Browse your way to your block library and then find the 'HA4D#'/'HA3S#' block with the # matching the one for the block you are swapping with.
Once you have selected the new file and returned to the dialog box, click OK to continue.
Now select the Source/Destination arrow you previously selected.
ACADE will now present you with a list of dwgs to process. select the dwgs to process and continue until the tool finishes.
Repeat for any other Source/Destination arrows as required.
 Regards Brad
Brad Coleman, Electrical Draftsman
