Solved by rhesusminus. Go to Solution.
Each report within the project has to have its own .set file.
I created .set files for each panel that would be in the project.
BOM_PEN1.set for Panel 1
BOM_PEN2.set for Panel 2
BOM_PEN3.set for Panel 3
etc...
It's stored in the table in the drawing, in some hidden data called XDATA.
Use the AEXDATA command to examine the tables. Then you'll se that the .set-filename is stored there 🙂
When you create a report, you can select a format file (*.set):
If you don't select any report file format, a default set-file will be used (bom.set in your case).
When you place the report in a table, Acade will save what kind of report and what set-files that was used, in the xdata for that table. This data will also be exported to the project database so that AcadE easily can find out what sheet it's located in:
If you now go to a random sheet, and create the SAME type of report, with the SAME set-file, AND you select "Update Existing":
AcadE WILL update the table on the sheet where the table already is inserted. As you see, you can select "Insert New", but it will not be updatable. Maybe this is ok with you?
So, if you have a BOM-table inserted on sheet 1, but want it to be located on sheet 3, you must first delete it from sheet 1 to be updatable.
Or... You can create different set-files for the different reports you want. Normally you would have a lot of set-files saved in a group within "Automatic reports" so it won't be as much work to create and update the reports.
It's not ideal by far, but this is how AcadE works at the moment
