Basic Relay Functionality Fail
I used the AECOPYCIRCUIT command to copy the top rung twice.
As you can see from the drawing, two of the copied cross-refences are working. However, four of them are broken.
I try again by deleting the broken symbols. I attempt to copy each component one by one using the AECOPYCOMP command.
However, when I try to change the parent reference or contacts I receive an ADS request error.
Performing a Database Lookup on the Parent component, the Data is there. So I do not know why an ADS request error would occur?
I am just a simple Electrical Engineer. I do not possess the advanced programming skills required to be proficient in AutoCADE and diagnose the root cause of this issue. Could someone please point me in the right direction?
