OK, an auxiliary contact is classed as a child component and gets linked to the parent (usually the coil) component.
The parent component is the only place where the catalog information is located within the dwg. This is why you add the aux contact block catalog information to it.
When you insert the child contact, you use one of the three options to select the parent component. This ties the contact to the parent you selected and fills in the cross reference data if that has been set up.
The pin list is information on the terminal numbers used in the contact block , relays and any other device that has terminals.
To access the pin list when inserting a component, click on the 'List' button in the Pins section of the dialog. If a pin list has been defined for the parent (or any aux blocks), you will get a list showing what contacts have been used and what matching contacts are available for use. ie NC contacts will only show changeover and NC contacts and NO will only show NO and changeover contacts.
If no pin list is defined or the catalog information has not been assigned, you will still get the dialog which shows the current pins, but no list of available contacts.
If you are testing the program before purchasing, I would look for a local reseller and ask them to come out and give a deomstration to you and any other people who are going to be using it as well as some of the management. If they can't come out to do a demo, they may have an in house demo you can go to.
If you purchase the program, I would see if you can also get someone to come out to give some hands on training to iron out difficulties like you are experiencing.
Regards Brad
Brad Coleman, Electrical Draftsman
