AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Automatic Wire Color/Gauge info in wiring diagrams
10 REPLIES 10
Message 1 of 11
526 Views, 10 Replies
Would anyone be able to give some direction as to how I can automatically include wire color/gauge info in my wiring diagrams based on the different wire layers that I've used for connections in my schematics. I thought that the *.wdw file was supposed to make this happen but it doesn't seem to be working for me.
I've set up my layers named "w_blk_#14" and "w_brn_#18" and then included each of those in the wire type table. Also, each exists in the *.wdw file with the description I'd like to use. The descriptions come into the schematic when I insert the color/gauge leader, but I though this was also supposed to work for my wiring diagrams. Am I wrong? Any help would be appreciated. Thanks,
Nathan
10 REPLIES 10
Message 2 of 11
Nathan
What annotation format are you using for your wiring diagram ?
%G - should give you color/gauge, or wire layer name.
But, I've found that the color (and probably gauge, although I'm not sure 'cos I don't use it) has to be entered into the 'Wire Color' column in the 'Create/Edit Wire Type' command dialog box (in Acade07, 08), otherwise it doesn't show up on the wiring diagram.
Pete B.
Message 3 of 11
Pete,
%G gives me the layer name, but that's no good because the layer names all begin with 'w' and are filled with underscores. I've got a few layers set up in the 'wire type table' but that just gives me the option of choosing which type of wire to insert in the schematic. I thought that the 'default.wdw' file was supposed to be used for wiring diagrams as well as color/gauge labels in the schematics. Any other suggestions? Thanks,
Nathan
Message 4 of 11
Is this what you where looking for?
http://discussion.autodesk.com/thread.jspa?threadID=389849
Peter
Message 5 of 11
Nathan,
Don't know if this helps, but I had a similar problem, in that I wanted :- WireNo/WireColor/Dest as the annotation, for which I was using - %W/%G/%I. If I remember correctly, I kept getting the Wire Layer for %G, until I added the colors as shown in the attached image.
Pete B.
Message 6 of 11
Peter,
The discussion thread was't was I was looking for. I read through that one already, but thanks! I have the wire layers set up as you showed in your picture. That doesn't seem to do anything for me either. All I ever get with '%G' is the layer name. Thanks for your help, but I guess I'll just have to live with it, or keep messing around until I find a way to get what I want! Later,
Nathan
Message 7 of 11
Nathan,
this isn't really my area of expertise but if you send me a drawing I can
look at it or have someone else here look at it. My direct email is
pat.murnen@autodesk.com
Pat Murnen
wrote in message news:5612348@discussion.autodesk.com...
Peter,
what I want! Later,
Nathan
Message 8 of 11
Nathan,
Just out of interest, which version of AcadE are you using?
Pete B.
Message 9 of 11
Pete/Pat
It's AutoCAD E 2008, and thanks for your suggestions. Thanks for the offer, but it seems to make more sense to me now that I just name the layers as I want them to display in my wiring diagram, and select the wire type at the command prompt when I begin a new wire. I was working under the assumption before that I would select the working layer before drawing a new wire, so I wanted all wire layers to be grouped together, hence the "w_". So I'll just set my templates up with the layers that I need, named the way I'd like to see them in my WDs! Thanks for everything,
Nathan
Message 10 of 11
Nathan,
I have a question for you. You seem to be one of the few using Wiring Diagrams and in AcadE08.
If you insert your WD footprints(from Schematic List) & then insert Terminals(from Schematic List) and then add 'Wire Annotations', does this work properly for you?
I seem to be having problems in '08 in that just the terminals get annotated and not the other footprints.
Yet, if I try the whole procedure, using the same Schematic, in AcadE07, it works fine!!
Cheers
Pete B.
Message 11 of 11
This is an issue that surfaced in ACE2008. We are working on a solution.
Please email me at nate.holt@autodesk.com for more info.
Nate.
wrote in message news:5613957@discussion.autodesk.com...
Nathan,
works fine!!
Cheers
Pete B.
