Since (January) we are using ACE2016. Before January we are using the ACE2014 version.
Since we using ACE2016 we have a lot of internal and fatal errors. For example see attchment.
This error we get when changing or updating a component.
Does anybody recognize this? Does anyone have an idea / solution?
Regards
NOt much to find on that error.
Could it be some add-ins that you have installed?
Type APPMANAGER at the command line, and see if you have some strange add-ins installed.
Does this happen to multiple computers?
Have you tried running a reset? https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to...
The apps we have, are only the pre-installed Autodesk apps.
Yes, it happens to more computers.
We have a brand new and clean computer system. After the first errors we have also tried the reset function.
Regards
I have admin rights.
When I want to run as administrator there pop-ups an alert. Alert attached.
This is the path were the .arg file is stored.
"C:\Program Files\Autodesk\AutoCAD 2016\acad.exe" /language "en-US" /product "ACADE" /p "O:\Autodesk\Acade\Profile\ACADE.arg"
Regards
ACADE.arg exists on the server.
The profile I'm using is already <<ACADE>>. See attachment.
Regards
We are using OS Windows 7. See attachment.
UAC is not disabled. See attachment.
It is posible to disable the antivirus for a while.
Regards
I would like to try it for a couple of day's.
To protect our systems we have installed Trend Micro Security Agent. We use this anti-virus now for 8 years.
Yes it happens in all projects.
...last friday there pop-ups an another error! See attachment.
This error came when I use the function edit component.
Do you like to receive the details of this error. Wow, it will be a lot of pages.19 pages!
Regards
Thats right, it shows me the description.
Thats was with anti virus on.
The anti virus is now switched off. I will work today without anti virus.
Regards
@VinodBalasubramanian maybe you can check up on this one...
Thanks for your support.
Do you know when I can get a response from Vinod?
This problem is very annoying.
Regards
I would be nice if you could have a look at this one.
Sure no problem.
HVEE,
May I know where you are based out of and also if you could PM your contact details and your convenient time. I would arrange a call from my end.
