AutoCAD Electrical vs Fusion 360 Electronics
CaptainMJ
Message 1 of 9
CaptainMJ
Hi All,
A simple question for you all! I am currently using Fusion 360 Electronics for making schematics and generating PCB's. I'm interested to know what the main difference is between Fusion 360 Electronics and Autocad Electrical. My initial thought is that AutoCAD is more for Power Electronics and Fusion 360 is more for circuit boards but I could of course be completely wrong here. Would be happy to hear some input on this.
Best Regards,
Marcus
Replies (8)
Message 2 of 9
rhesusminus
AcadE is mainly directed against panel builders and the likes, and as you've figured out, not against electronics/pcb's.
Fusion 360 Electronics is competing against Autodesk Eagle for your attention 🙂
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 3 of 9
CaptainMJ
Thanks for the explanation, that's exactly what I wanted to know!
Best Regards,
Marcus
Message 4 of 9
galashkina
In AutoCAD Electrical, wires, cables, harnesses, and pipes are used for connections between components. Wire is assigned a color, cross section, number of the electric circuit, etc. Cable is assigned a cable’s name, colors and section lived, etc. This information is used in reports (text documents), for example, the connection table, the cable magazine, etc.
Other parameters are set for PCB conductors, such as the width of the conductor, the layer of PCB, the size of the transition hole, and so on. These parameters can not be assigned in the AutoCAD Electrical.
AutoCAD Electrical is used for designing objects where wires, cables, harnesses, and pipes are used for connections between components, but not printed conductors.
Message 5 of 9
CaptainMJ
Many thanks for the clear explanation.
Best Regards,
Marcus
Message 6 of 9
stalin.varghese90
How do we represent a harness in AutoCAD Electrical ?
Message 7 of 9
rhesusminus
https://knowledge.autodesk.com/support/autocad-electrical/getting-started/caas/CloudHelp/cloudhelp/2...
Trond Hasse Lie
Ctrl Alt El
Message 8 of 9
galashkina
My examples of wire harnesses in AutoCAD Electrical.
Block. Connection diagram.
Show connection lines.
Drawing of the block layout and the relationship between the schematic image and the layout image.
Message 9 of 9
galashkina
Wiring diagram for level, temperature, pressure, etc. sensors to the cabinet terminals.
Sensors and harnesses in a 3D model of a boiler room (AutoCAD Electrical & Inventor).
