AutoCAD electrical multi-layout printing
rfoxA5QU8
rfoxA5QU8
Community Visitor
Community Visitor
Why does electrical project plot only support one/(first) layout printing. How does one fix this, printing mutli-viewports with there own layout, that are zoomed into different terminal block sections of a panel layout for enhanced detail.
pendean
Community Legend
Community Legend
@rfoxA5QU8 wrote:
Why does electrical project plot only support one/(first) layout printing....
Which command are you using? Nothing is called "print" for example, so please be more detailed.
For example:
PLOT command is a single "page" output, and with layouts it only outputs the one layout you are in.
PUBLISH command does more if you need to output many LAYOUTs.
rfoxA5QU8
Community Visitor
Community Visitor
This is using the project plot button in the AutoCAD electrical project tree window(right side, top of window) to send the whole project to PDF.
arshdeepsingh404
Hello @rfoxA5QU8
I would suggest using the BatchPlot option (command name _PUBLISH) for creating the PDF.
Under Sheet Name, you can select all the layouts that you wish to plot.
You will have to make sure when you click on the small green plus (Add Drawings button), The include option is set to Model & Layout.
Arshdeep Singh
Electrical Designer & Programmer
C.Tech | CAPM® | CMSE® | Autodesk Expert Elite
LinkedIn
Autodesk App Store
Did you find this post helpful? Please feel free to Like this post.
Did your question get successfully answered? Please click the Accept Solution button to help other users who may have the same question.
pendean
Community Legend
Community Legend
Do you mean this
That creates single separate PDFs for each, in this sample above, all from modelspace, not layouts.
rfoxA5QU8
Community Visitor
Community Visitor
Yes, the version we run on the last window is two check boxes, model , first layout. This is where I was kind of locked into. Looks like I can only setup my own batch plot script, manual pars each file in the 500+ files in the packages we output to have the layouts selection added to show up in the correct order in the PDF file.
