AutoCAD Electrical custom wire button
swansbh
Message 1 of 11
swansbh
I am looking to create a custom icon that would automatically select a certain wire layer for the user and allow the user to lay a wire down that uses that specific wire layer.  So I am looking to merge the "Wire" command and the "Change/convert wire layer" buttons into one but for specific wire layers to be selected.
Any ideas on how to go about doing this?
Brian
AutoCAD Electrical 2017
Replies (10)
Message 2 of 11
swansbh
I really meant to say "Create/edit wire type" and change the default wire layer to a specific layer then the wire command runs.
Message 3 of 11
rhesusminus
Try this macro:
^C^CCLAYER;WIRE_LAYER_NAME;AEWIRE
BUT!!.. Stay away from having a caret "^" in the layer name. This character have a special meaning in button macros.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 4 of 11
jseefdrumr
4,000 points to Trond for the correct spelling of 'caret'.
I wish I worked with people whose command of the English language were as good as yours. And I'm from here!!!!
Jim
Jim Seefeldt
Electrical Engineering Technician
Message 5 of 11
swansbh
Trond, this works exactly based upon what I had asked for.  Next level question, is there a way to accomplish this without changing the current layer?
Brian
Message 6 of 11
rhesusminus
I didn't find a workaround for that.
According to the API help file, this line should do that:
(ace_set_default_wiretype "LAYER NAME")
But.. I couldn't get that to work. Maybe @Anonymous can have a look at that API-call?
Trond Hasse Lie
Ctrl Alt El
Message 7 of 11
PatMurnen_Adsk
That API seems specific to when you insert circuits. The API name is misleading I think.
But, I did find that (ace_set_current_wiretype "lay_name") sets the current wiretype for the AEWIRE command. So I would use that in place of the LAYER command and it won't change the current layer but just change the current wire layer. I am not sure why this API  isn't in the API Help. I will log this.
Pat
Pat Murnen
Principal Content Developer
Product Development – AutoCAD Product Line Group
Autodesk, Inc.
Message 8 of 11
swansbh
Pat, maybe I am doing something wrong but in ACADE 2017 the command you listed is coming up as unknown.  Here is my current command string.
^C^Cace_set_current_wiretype;DRS_BUS_BAR;AEWIRE
Brian
Message 9 of 11
PatMurnen_Adsk
This API is a little different call. I can't try this as I am on a computer in a meeting without AutoCAD Electrical. But try with the parentheses -
(ace_set_current_wiretype "DRS_BUS_BAR");AEWIRE
Pat
Pat Murnen
Autodesk, Inc.
Message 10 of 11
swansbh
Thanks pat this seems to have worked.
B
Message 11 of 11
PatMurnen_Adsk
Glad that worked. I logged the issue that this API is missing from the API documentation.
-Pat
Pat Murnen
Autodesk, Inc.
