AutoCAD Electrical 2026 can not screate .scr script file
diegozanella3991
diegozanella3991
Hello All,
I am experiencing quite a blocking behaviour from my AutoCAD Electrical 2026 and I could not find any solution online for it.
When I try to make Wire Sequence Update throughout the Project, I am getting the following message
When I click OK, the process is not performed and the following message appears:
Do you know how I can solve the issue? I have seen that it occurs when I try to perform any task throughout the whole Project (e.g. Surf command), and it gets very annoying.
Thank you very much!
Diego
rosie_lucas1
Hi @diegozanella3991,
Just following up - were you able to resolve the issue, or do you still need help?
If you’ve found a solution, we’d love if you could share it here so others can benefit. If not, feel free to post an update anytime.
Best regards,
Rosie | Community Manager
arshdeepsingh404
Is this issue project-specific or throughout AutoCAD Electrical? Is your project local on your computer, or are you trying to access it from a network location?
Can you try to check if you are seeing the same issue on the demo projects that come with the AutoCAD Electrical installation?
Arshdeep Singh
Electrical Designer & Programmer
C.Tech | CAPM | CMSE | Autodesk Expert Elite
LinkedIn | Autodesk App Store | GitHub
Did you find this post helpful? Please feel free to Like this post.
Did your question get successfully answered? Please click the Accept Solution button to help other users who may have the same question.
diegozanella3991
Hello All,
I managed to solve the issue thanks to Copilot. The Antivirus software of my company was blocking the creation and execution of .scr files by AutoCAD Electrical 2026. We changed then the settings of the Antivirus software and the problem was solved.
Hope this can help.
Best regards!
