Hi all,
My client is using Vault 2021 and has installed the client on my machine along with Inventor 2021. I am trying to connect with the vault with ACADE 2025 but there is no Vault Tab. I installed Vault 2025 and the Vault tab appears but I cannot connect with the server because it is Vault 2021.
When I uninstalled vault 2025, the Vault tab goes away.
How do I get ACADE 2025 to see Vault 2021 client?
Vault 2021 Client was installed after ACADE 2025 and a colleague is using vault 2021 (same server) with ACADE 2024 so it should work.
The Vault installation was installed and is used over a VPN. The installation took 6+ hours so I really don't want to do a re-install if I can avoid it.
Thanks so much for any help i can get as I need to get back to work.
Thanks, Steven
