AutoCAD Electrical 2021 - Text and Font Thickness Randomly Started Acting Weird and Thiccc
Message 1 of 8
I got 2021 a few months ago, and sometime after that (not right away), all my text objects suddenly got thick, as if they are block letters with hollow insides and outlines for their bodies. I didn't make any changes to make this happen. One day everything was normal, default, shows as 0 thickness, then the next day everything is all blocky. I can't find anything that is set weird. It does it on component attributes, text, mtext, attributes inside of blocks, myu line numbers, everything. I have all my lineweights set to default, and my default is .13mm (for printing) and I DO NOT have the option checked for displaying lineweight (my assumption is that is talking about displaying the printing lineweight in the actual model space while working).
Please help me, because it's driving me crazy lol.
Replies (7)
Message 2 of 8
rhesusminus
Got to AutoCAD options, and make sure the font mapping file is set to acad.fmp, not acade.fmp:
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 3 of 8
Mine is set to acade.fmp so I'll change it and see if that fixes it. Fingers crossed!
Message 4 of 8
Hey! This worked! Thank you so much. It doesn't particularly matter, but why are the acad and acade fmp files different like that? Do you know?
Message 5 of 8
rhesusminus
When you publish to PDF, with the "substitute fonts" option on (to create s searchable PDF), they change the font mapping file temporarily to the AcadE.fmp.
Sometimes, they "forget" to reset it back to acad.fmp, hence the random nature of it.
I would consider it a bug, but don't bother reporting stuff like this anymore.
Trond Hasse Lie
Ctrl Alt El
Message 6 of 8
Great details to have. Thank you for sharing about this. Much appreciated!
Message 7 of 8
Blackdog9
Thanks for this information. it saved my sanity
Message 8 of 8
selijerome
i was having same issue since i reinstalled the autoCAD. Replacing it my acade.fmp works for me too !!
But i changed WD, standard and romans to Arial, ttf. And it worked perfectly.
Thanks.
