AutoCAD Electrical 2021 Migrate Settings from Previous Version
How do I properly migrate my settings from AutoCAD Electrical 2020 to AutoCAD Electrical 2021? I don't see the "Migrate from Previous Year" that everyone says should be available in the windows start menu. When installing that box was checked, but I was not prompted past that to specific to migrate from ACADE 2020.
What's the proper way/recommendations for installing a new version/year of AutoCAD Electrical? It seems like the responses for migrating settings always default to how generic AutoCAD/AutoCAD LT is done, but from my understanding ACADE is different and cannot be done the same way.
Any feedback or potential solutions are greatly appreciated! 🙂
rhesusminus
If they are installed on the same computer, you should be able to select this:2020-03-31_11-01-32.pngct thi
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
What about system variables? Does any of this bring system variable settings over? Or do you need to use something else to get those?
rhesusminus
"Note: Some versions of AutoCAD do not have a settings migration utility. Migrating settings for these versions is not a supported process."
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-m...
So.. AutoCAD Electrical is one of those 😄
Trond Hasse Lie
Ctrl Alt El
Hightower_AV
I'm a bit late to this but thank you Trond for this information. I'd always stayed away from the Migrate utility as I assumed it was the Content Migration and I didn't want to convert my databases to SQL. I am currently upgrading our install from 2020 to 2024 and this has helped a lot. 🙂
