I am currently running Electrical 2017, when I am inserting a component while on the schematic tab. Whenever I hit ok, the program locks up. If I hit "Ok-Repeat" it works fine. On the command line, it reads, "reading project database file......" while it is locked up. Nothing in Electrical will work, unless I go to task manager and close out the program and restart. I have waited close to 20 minutes one time while it was locked.
I tried that and did not solve the issue. It is not on all the components, so far it's only been square terminal with wire number, round terminal with terminal number. Everyone in our department is having the issue. I just been clicking on Ok-Repeat and ESC afterwards for the time being. Thank you for the help.
