Are there any good third party plugins or scripts to automatically move and scale XY references based on titleblock border?
I'm converting a drawing set from ladder references to X:Y grid references. Some of the drawings in the set are pretty information dense, and some of them are pretty sparse.
For those sheets which are relatively dense, we would prefer to sacrifice a little readability by making the content smaller relative to the title block, than to split the pages up since we are replicating an existing set of prints for which the customer could not find any dwg files.
As I see it, to use X:Y referencing, I can either:
A) Scale the contents of each drawing to fit within a title block of fixed sized (from drawing to drawing) so that I can set my X-Y grid origin and spacing to be the same on every sheet.
B) Scale the title blocks on each sheet to fit the contents. This requires origin and spacing parameters to be set on a drawing by drawing basis.
Option A is undesirable for our work flow because we copy a lot of components and circuits from sheet to sheet, and the time it will take other engineers to figure out how much I scaled any given component in this package will add up over time.
Option B will require more time up front, but will avoid scaling compatibility issues down the line.
Is there a third option I'm not aware of? Perhaps there is a script that will allow a user to select a title block's legend and set the drawing's X-Y grid reference settings base on the legend's location and scale?
Thanks!
