Aligning Dimensions not working
Matt__
Matt__
Cannot find any info on aligning Ordinate dimensions, DIMSPACE does not work for ordinates.
Any help would be appreciated, thanks.
Matt.
jseefdrumr
I'm not sure about the best way to do this if they're already drawn. There is no command that I'm aware of. You may be faced with having to use grip editing and drawing points to snap to.
When drawing these in the past, I seem to remember drawing the first ordinate normally, and then using DIMCONTINUE to draw the rest. Could that work for you?
Also, one of the other forums might be more help, dimensions aren't really used that often in ACADE.
Hope this helps,
Jim
Jim Seefeldt
Electrical Engineering Technician
Matt__
dimcontinue works perfectly, exactly what i was after.
