Adding support/libraries to Vault from Autocad Electrical
Niklas_BalkHJBPA
Niklas_BalkHJBPA
Hi all,
I'm still kind of new to ACE and Vault, my company currently uses both and I was wondering about the correct way to add the support libraries, icon menu stuff, etc to Vault so that my entire team can reference the same libraries. If I try to drag and drop a DWG file or use the "Add Files" feature, it throws this error:
I understand that this restriction can be disabled by the Vault administrator, but I figure this means it is probably the wrong way to add these files. Please let me know if you are aware of the "correct" way to do this.
rhesusminus
You really should ask this in the Vault forums. Not too many users here using AcadE with Vault. Good luck. You'll need it.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
CGBenner
This post was marked Solved by @Niklas_BalkHJBPA  in THIS thread on the Vault forum.
Chris Benner
