Adding relay modules using spreadsheet to PLC I/O utility
I'm trying to learn how ti use the spreadsheet to PLC I/O utiliy in autocad. Using the spreadsheets as normal is perfectly fine and easy. The problem im having is inserting relay modules using the utility. I havent seen any documentation on this at all. This is what im trying to do, (which was drawn up by hand).Capture.PNG
Left side is the PLC, middle is the relay module, and the right side is the feild instrument side.
rhesusminus
The PLC I/O generation mainly revolves around the I/O's.
Each I/O has one line in the excel sheet.
So, to manage to do something like this, you have to divide your relay module into multiple parts, like in this drawing:
But, I'm really not sure that you'll be able to get it excatly like you want it...
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
