Hi @luke_cope
You could be fighting more than one issue here. Let's break it down and perform some tests in steps.
1. Run the AECATALOGCONFIG command and check what is path set for the Catalog Database
2. Open the catalog browser and add a new component to any standard family like a Pushbutton.
3. Close AutoCAD Electrical and browse to the .mdb location noted in step 1 and check if the new entry made it to the database.
Give it some time to sync if using a network location. Check what the last modified timestamp of the database.
4. Insert a standard AutoCAD Electrical symbol like a Pushbutton (Not a custom made one) and assign it the new catalog.
Sometime the issues are just with the symbols so lets try this on standard symbol that is provided by AutoCAD.
5. Run a standard BOM Report (AESCHEMATICREPORT) on the active drawing only.
Lets see where the disconnect happens when you have performed all these steps.
Have a read at this thread, I have explained the issue with OneDrive in this and how to setup a SQL catalog instead.
https://forums.autodesk.com/t5/autocad-electrical-forum/changing-database-locations/m-p/12872019/hig...
Arshdeep Singh
Electrical Designer & Programmer
C.Tech | CAPM® | CMSE® | Autodesk Expert Elite
LinkedIn
