Adding fixed suffix to wire numbers
My employer insists on using a fixed suffix on wire numbers for different remote enclosures. For example, one enclosure might be designated "AS", and another enclosure will be designated "AT". They also use the number "9x" to designate remote enclosure wiring numbers.
All that being said, as an example, remote enclosure "AS" will start with wire numbers 9100AS, 9101AS, 9102AS... etc. The next page will be 9200AS, 9201AS, etc.
The next remote enclosure "AT" will start with wire numbers 9100AT, 9101AT, and so on
(an example of some rungs attached)
This is a reflection of outdated methods of creating wire numbers for schematics that did not utilize AutoCAD electrical, but now we have a situation that requires AutoCAD electrical, I don't know of a way to add a fixed suffix to wire numbers. Adding a fixed prefix would be easy, but if you begin a wire ladder with 9100AS, the next wire number will be 9100AT, and so on (example attached).
My fear is that there isn't going to be a way to add fixed wire number suffixes like I require, and I dont know of any way to manually override it line by line, as any component's %N value will still register as the original wire number if I edit them one by one. Any advice on this would be greatly appreciated.
