Adding Child Cross Reference to Parent With No Pins
andrewH6NGQ
andrewH6NGQ
Hi, I have been using ACE for a few months now and I am really getting the hang of it, thanks to various resources such as Nate Holt and Doug McAlexander.
I have a customer that I have been doing work for and I have been trying to replicate their method of design but there is one aspect I haven't figured out how to replicate; showing the cross-reference of a child part's pin on the parent symbol.
Their designs use Beckhoff industrial PCs with I/O slices. In their design they will have pages that show a group of IPCs or I/O slices that show which page each of their channels is shown on. Ex: DI02 CH1 (Pin 1) is at =02 Sheet 5, and when you go to that page you then see a single box with a pin connection for channel 1.
I have not used the PLC toolsets to generate my symbols for these parts but I have instead created them as regular components with the family code DV and I have had no issues with anything thus far. What I did was make the parent a horizontal component with no pins just to carry the catalog and connection data, but then I made generic vertical child components that would carry the connections. I made them in 1port, 2port, 4port, and 8port flavors.
What I would like to do is replicate their method of showing a child part's cross-reference next to the appropriate graphical pin on the parent symbol. I want this to have intelligence to it so I don't have to manually make text each time. I don't mind building this into the part's footprints if need be.
1. Is pinlist the thing I need to utilize?
2. If so, how do I do that exactly?
3. If not, what tool?
4. Likewise, how would I use that alternate tool?
rhesusminus
It's not possible to achieve this with standard functionality in AutoCAD Electrical. Cross-references are only shown in one location at a parent symbol, and a child symbol will only point back to the parent component with its cross-reference.
Your screenshots are from EPLAN where cross-references are solved a little more flexible.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
rickstarosto4361
all of our drawings have the same OLC format you have shown I too asked this question, but no success. i do usw EPLAN also, i wish ACADE would have thought out side the box as far as TRUE customized symbols.
