Announcements
AcadE Balloon Problem
I have a problem when I place a balloon in AutoCAD Electrical kin a project the balloon and the balloon is selected (for any reason) basically I can select individual lines to move. Where when others select the balloon they only have one pick point and it puts a select rectangle around the whole balloon.  I figure It is a wrong setting somewhere can anyone help with this
jseefdrumr
Try setting PICKSTYLE to 1.
Jim Seefeldt
Electrical Engineering Technician
testsubject
Item balloons are Groups so check if you inadvertently pressed CTRL+SHFT+A. This will turn Groups On and Off.
As James mentioned, PICKSTYLE will also switch this On and Off.
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
thank you thank you thank you it has been driving me nuts 🙂
