Ability to fill in relay contact info from a pre-filled Table
michael_mcdonald6VFQT
Hi all! This is more geared to substation design. I use SDS, so I know that I can make my relay, add all my INs, OUTs, and contacts as needed, name them, and then put down a table for that relay and have ACAD E autofill that table with the information I want.
I was recently asked if the reverse is possible. If I can take a table with information in it as defaulted and, as I make the relay and place down INs, OUTs, and contacts, choose values from that table to apply to the relay (such as PIN number, the description, etc).
arshdeepsingh404
If you assign a catalog to the relay, then the contact PIN number can be populated from the values defined in the PINLIST field in the catalog browser.
You won't be able to do the same thing for descriptions though.
Arshdeep Singh
Electrical Designer & Programmer
C.Tech | CAPM® | CMSE® | Autodesk Expert Elite
LinkedIn
