Add the ability to place an elevation label at any point on a feature line. This should be similar to a surface spot elevation and include a marker so the elevation can be dragged.
I use feature lines as break lines in my surfaces. Certain critical points need to be labeled.
It is useful to label feature lines directly the labels are dynamic in the X, Y and Z direction. Surface spot elevations are static in the X and Y direction but do reflect Z changes.
