editing overlapping alignments
Bringing up 'edit alignment geometry' should disable picking alignments other than the one picked for editing after selecting an editing option from the toolbar.
It is countless clicking on the screen currently when trying to connect alignment elements, as wrong alignment gets selected, if some element overlaps with undelaying other alignment.
You have an otpion to hide temporarily the other alignment of course, but this could be avoided I believe.
I'm still on Civil 2017, maybe this is fixed in 2018 already?
2 Comments
AdammReilly
I love the ability to quickly switch between alignments just by selecting them when that toolbar is open, so I would prefer a button added to the alignment editor toolbar that lets you lock the current alignment selection.
The same could be said for profiles, too.
robert06
The workflow should be selecting the alignment to edit first like it is now otherwise it's a mess. If you start with a command not setting an alignment active first, you can pick only the elements in front defined by acad draw order if alignments overlap.
In other words when the alignment edititing toolbar is open, by clicking an alignemnt it becomes active in the toolbar. After hitting a command botton (then you're in middle of a command), picking all other objects except the active alignment should be filtered out.
Answer Day
Rail Community
