When I tried to copy circle with filling I only get the circle. I have to fill each circle separately.
I have tried many times.
Not really comfortable considering the amount of work.
A screenshot was attached. (AutoCad 2018)
All the best,
Yana
@y.kluchnik, it looks like you are new to AutoCAD (trial ve5rsion) and to the Forums (first post.) Welcome!
This forum is for Ideas about improvements to AutoCAD Civil 3D, not general AutoCAD problems.
You might get a better response in the AutoCAD Forum.
(Click forms above, click on AutoCAD in the program list, then click on AutoCAD Forum in the Browse list.)
Because you seem new to AutoCAD and to the Forums, I will try to address your problem:
Since you did not attach your drawing I am making my best guess.
The "Fill" is probably a hatch using the solid pattern. The circle and hatch are two separate objects.
This is how AutoCAD work, and is by design. You have not found a bug.
By default a hatch made from a circle is associative:
Because the Circle and hatch are two separate objects:
You circle and hatch are a great candidate to be made into a block. Block are powerful AutoCAD objects that are good when you need to repeat the same thing multiple times in a drawing or constantly in multiple drawings. A lesson in AutoCAD block is beyond what I can do in this reply.
These forums are a great resource. Autodesk employees occasionally respond, but for the most part you will be dealing with time limited volunteer users. Some hints on using the Forums:
***** End of Lesson *****
@y.kluchnik, good luck on your AutoCAD journey. Hopefully you will soon achieve the "Love/Hate" relationship many users have with AutoCAD.
(Currently, my "Hate/Love" relationship with AutoCAD Civil 3D is overshadowed by my "Hate/Anger/Quit Desperation/Grudging Acquiesce" with Civil 3d Grading Objects among other Civil 3D peculiarities.)
Christopher Stevens
One more point - please use image formats for attaching screenshots. Docx files can contain macros, so the more security conscious will not open them.
Thank you for your reply. I have been using AutoCad for a long time but another version. And it has never happened to me. For sure I know how to use it)
I was looking for where I can leave this message that it would be more suitable. Couldn't find just AutoCad section.
Sorry, @y.kluchni. I hope I didn't offend.
By the way, I do not have this problem with Civil 3d 2018, but I am not sure that I understand what the exact problem is.
Have a nice weekend.
Christopher Stevens
Hi @y.kluchnik,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
I am curious to see a sample drawing form you that shows this issue. If the hatch, for instance, is on a locked layer I can understand why it did not get copied with the circle.
Please attach a file so I can investigate this issue for you.
All the best,
Yana
Яна! Так как Вы используете русскую локализацию AutoCAD, то рекомендую задать этот вопрос здесь: AutoCAD - Русский - Autodesk Community
Желателен образец чертежа и видео операции копирования (видео рекомендую делать при помощи Autodesk Screencast)
Что такое заполнитель окружности? Штриховка типа SOLID? Штриховка ассоциативная? В этом случае она копируется вместе с окружностью. Если нет, то и копироваться она не должна если не выбрана вместе с окружностью.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
HI,
>> When I tried to copy circle with filling I only get the circle. <<
But as i see from the rubber-band line (orange dashed line ) in your attached image that your selected circle is already filled !!! would you please attache your CAD dwg (or a part of ) here for testing ?
